The FIAT Forum
Go Back   The FIAT Forum > Miscellaneous > I.C.E
Old 14-05-2008   #1
meow
beau's Avatar
Trader Rating: (15)
beau has donated! United Kingdom
2 ohm speaker wiring
do you have to wire speaker to amp different for 2 ohm? im really confused lol.
my amp (jbl 75.2) is rated at 97 watts x 2 at 4 ohms or 145 watts x 2 at 2 ohms, now my speakers are 2 ohm, how do i wire them up? cos i thought you have to wire them different.... not got a clue though maybe im wrong tho, atm iv just put the - into the - and the + into the + but im sure iv read about running wires parralell or something for 2 ohm, oh i duno, help!
PUNTO JTD
beau is offline
Old 14-05-2008   #2
Trader Rating: (0)
Re: 2 ohm speaker wiring
I'm guessing you've got Infinity/JBL speakers, right? You wire them exactly the same as 4Ohm speakers.
Its only different when you're running a dual voice coil subwoofer.
JayEm is offline
Old 14-05-2008   #3
meow
beau's Avatar
Trader Rating: (15)
there infinity.
but why if they run 2 ohms dont they sound any louder than if i run a set of 4 ohm speakers on there?
PUNTO JTD
beau is offline
Old 15-05-2008   #4
Trader Rating: (0)
They're not really 2 Ohm, closer to 3 Ohm actually so you won't hear much of a difference. Make sure you have the amplifier gain and HPF set properly.
JayEm is offline
Old 15-05-2008   #5
paulbfd's Avatar
Trader Rating: (0)
paulbfd has donated! United Kingdom
Twice the volume needs four times the power, roughly.
So if Jays right about them being nearer 3, you're not going to get a huge increase.
Bigger amp more power FTW!
Black 100HP
Alpine CDA-7944, PXA-H701 processor and RUX-C701 controller.
Hertz Mille MLK2 components, Mille 10" subwoofer and HP4 amplifier.
paulbfd is offline
Old 17-05-2008   #6
Trader Rating: (0)
Loudness will also depend on the sensitivity of the speakers used.
fokker is offline
Old 17-05-2008   #7
Gutten Morgan
volxstu's Avatar
Trader Rating: (0)
volxstu has donated! United Kingdom
What speakers are you trying to run at 2 ohm's if you have two then it is always possible it may not be practical for Mit and Trebble playing speakers. But if you are trying to run two subs then this can easily be done by connecting the polarites of the subs together and then one of those to the amp so you could bridge the two channels of the amp wich should give you 300w RMS.
Do a quick search on Goooooooogle on two ohm wiring and there is a ton of info out there.
Originally Posted by Tris Harris View Post
I have tried to stay on here incase anything remotely interesting popped up me...
a chocolate finger sounds good
volxstu is offline
vB code is On
SPEAKER Wiring Colours Digi Dreamer Punto > Technical 4 16-03-2007 18:53
Mixed ohm ratings & do you set the ohm ratings? CaneyJ I.C.E 3 16-05-2006 21:53
Speaker Wiring CinquePunto Punto > Technical 3 18-06-2005 10:28
speaker wiring gaz.d Punto > Technical 17 13-05-2005 15:52
Rear speaker wiring? ScottieCinq I.C.E 3 25-05-2004 21:02
