| meow | 2 ohm speaker wiring do you have to wire speaker to amp different for 2 ohm? im really confused lol. my amp (jbl 75.2) is rated at 97 watts x 2 at 4 ohms or 145 watts x 2 at 2 ohms, now my speakers are 2 ohm, how do i wire them up? cos i thought you have to wire them different.... not got a clue though maybe im wrong tho, atm iv just put the - into the - and the + into the + but im sure iv read about running wires parralell or something for 2 ohm, oh i duno, help! ![]()
__________________ ![]() 1993 Uno Turbo / 1995 Punto 55 / 2000 Punto jtd | ||
| Re: 2 ohm speaker wiring I'm guessing you've got Infinity/JBL speakers, right? You wire them exactly the same as 4Ohm speakers. Its only different when you're running a dual voice coil subwoofer.
| | #3 | |||
| meow | Re: 2 ohm speaker wiring
but why if they run 2 ohms dont they sound any louder than if i run a set of 4 ohm speakers on there? ![]()
__________________ ![]() 1993 Uno Turbo / 1995 Punto 55 / 2000 Punto jtd | |||
| | #4 | ||
| Re: 2 ohm speaker wiring They're not really 2 Ohm, closer to 3 Ohm actually so you won't hear much of a difference. Make sure you have the amplifier gain and HPF set properly.
| | #5 | ||
| Re: 2 ohm speaker wiring Twice the volume needs four times the power, roughly. So if Jays right about them being nearer 3, you're not going to get a huge increase. Bigger amp more power FTW!
__________________ Black 100HP Alpine CDA-7944, PXA-H701 processor and RUX-C701 controller. Hertz Mille MLK2 components, Mille 10" subwoofer and HP4 amplifier. Chord Epic speaker cable and Anthem RCA leads. | |||
| | #6 | ||
| Re: 2 ohm speaker wiring Loudness will also depend on the sensitivity of the speakers used.
| | #7 | ||
| More ICE Please | Re: 2 ohm speaker wiring What speakers are you trying to run at 2 ohm's if you have two then it is always possible it may not be practical for Mit and Trebble playing speakers. But if you are trying to run two subs then this can easily be done by connecting the polarites of the subs together and then one of those to the amp so you could bridge the two channels of the amp wich should give you 300w RMS. Do a quick search on Goooooooogle on two ohm wiring and there is a ton of info out there. | ||
| SPEAKER Wiring Colours | Digi Dreamer | Punto > Technical | 4 | 16-03-2007 18:53 |
| Mixed ohm ratings & do you set the ohm ratings? | CaneyJ | I.C.E | 3 | 16-05-2006 20:53 |
| Speaker Wiring | CinquePunto | Punto > Technical | 3 | 18-06-2005 09:28 |
| speaker wiring | gaz.d | Punto > Technical | 17 | 13-05-2005 14:52 |
| Rear speaker wiring? | ScottieCinq | I.C.E | 3 | 25-05-2004 20:02 |
