The FIAT Forum
Go Back   The FIAT Forum > Miscellaneous > I.C.E
Old 04-05-2008   #1
Trader Rating: (0)
Punto 2b power cable
Does ANYONE know how to get the bastard through from the engine compartment into the main thing? Its torturing me.
Loads of love for anyone who tells me.
Ba-2-Rez is offline
Old 04-05-2008   #2
PuNtO PoWeR
Trader Rating: (0)
1383matt has donated! United Kingdom
Re: Punto 2b power cable
there is a grommet behind the battery pull it out feed cable through there comes out underneath glove box, ill attach pics in morning.
Matt
1383matt is offline
Old 05-05-2008   #3
taffy git
gaz.d's Avatar
Trader Rating: (2)
gaz.d has donated! Poland
under the abs pump, there is a hole cut out in the fire proofing, poke it out and it reveal plastic bung
inside the car, pull carpet back from passenger foot well and there a square cut out, remove it and you see a hole
if you using thick cable it can easily be drilled and no risk of damaging anything else
few years since i did it though
Events Calendar
Sunday 10th August Mitcar
Sunday 7th September Trax
Sunday 14th September Gaydon
19th-22nd September Butlins Skegness Weekender
gaz.d is offline
The following user says "Thank You!" to gaz.d for this useful post:
Ba-2-Rez (05-05-2008)
Old 05-05-2008   #4
PuNtO PoWeR
Trader Rating: (0)
here we go pictures s promised...
one of them is the cable coming in behind the glove box.
ID:	43002  Click image for larger version
Name:	punto 1 (2).JPG
Name:	punto 1 (3).JPG
1383matt is offline
The following user says "Thank You!" to 1383matt for this useful post:
Old 05-05-2008   #5
Trader Rating: (0)
I Actually love you both.
Alot.
Ba-2-Rez is offline
Old 05-05-2008   #6
PuNtO PoWeR
Trader Rating: (0)
not a problem upload a pic when your done!!
1383matt is offline
Old 08-05-2008   #7
Trader Rating: (0)
Lol, i couldn't get at that because of my abs pump, but i had a stroke of genious and nicked a rubber tube heading into the bulkhead, after alot of wire poking, and a nasty gash to my knuckle i got the wire what i thought was through, looked in, and low and behold it was sitting in my passenger footwell =].
Ba-2-Rez is offline
Old 09-05-2008   #8
compensation needed
crazydave's Avatar
Trader Rating: (0)
crazydave has donated! United Kingdom
If only i had this handy when i came to fitting power cable in the 2b, well i had fun drilling through my car to fit the 0gauge
Originally Posted by dave
crazydave, he realy is crazy
crazydave is damaged goods, and in need of some tlc
crazydave is offline
Old 13-05-2008   #9
Trader Rating: (0)
Heh, if it was 0 gauge you'd probably have had to drill anyway, it was awkward enough with 4awg
1.2 8v Mk2 Punto Active
CrArC is offline
Old 21-05-2008   #10
compensation needed
crazydave's Avatar
Trader Rating: (0)
it was fine running it through the rest of the car i.e. up the side trim and into the back, just took a while to get to the battery
vB code is On
Power Cable In Grande Punto Advice Needed kayum.abdul I.C.E 4 15-04-2008 17:07
amps power cable.. where?? edd_edd_edd Cinquecento / Seicento 4 11-10-2006 06:16
Where does power cable route through? gex18 I.C.E 4 14-08-2006 12:37
Amp power cable StiloJoe Stilo > Technical 10 30-03-2005 16:53
How would I go about wiring a power cable david6876 Panda (Classic) 6 25-01-2005 20:28
