The FIAT ForumThe FIAT Forum is in no way affiliated with or endorsed by FIAT S.p.A.
Forge Motorsport
Go Back   The FIAT Forum > Miscellaneous > I.C.E
Old 03-05-2008   #1
Polar Opposites
5abr3 has donated!
Smile Head Unit Skipping & Connectors
Hi all,
I'm currently running a JVC KD-G111 unit in a Mk1 Punto until I get around to updating the head unit, anyway I have 2 Questions:
1) The CD player skips randomly, and it doesn't appear to be the disc as it skips in different places after each pass. Could this to be with temperature? If that's the likely solution then I could try mounting some PC fans to draw the air down and off the unit (the detachable front gets hot regardless of the weather, day or night).
2) on the back of this head unit there is the standard audio connector, fuse, antenna in and two connectors that appear to be Phono sockets (the plastic is red on one and yellow on the other if that helps?) and to be honest I don't know what they are and the manual mentions nothing obvious about them. Are these 'pre-outs' for a sub/amplifier or something?
Thanks in advance
5abr3 is offline
Old 04-05-2008   #2
Polar Opposites
5abr3 has donated!
Re: Head Unit Skipping & Connectors
Found out that the connectors are for a none amp driven output, that just leaves teh cooling, anybody?
5abr3 is offline
Tags
connectors, head unit, heat, output, skipping
(T) Help With Ignition & Head Unit grandepunto4life Grande Punto 12 25-03-2008 22:06
Stilo standard Head Unit/amp volxstu I.C.E 0 15-08-2007 09:11
(T) Blue & Me + New Head Unit? venomco Grande Punto 16 17-06-2007 09:06
Head Unit Connectors solid1 I.C.E 8 23-12-2003 22:13
Copyright ©2002 - 2010 FIAT Forum
