The FIAT Forum
Go Back   The FIAT Forum > Miscellaneous > I.C.E
Old 19-04-2008   #1
Hills are my enemy!
Eklipze3k's Avatar
Trader Rating: (0)
Eklipze3k has donated! United Kingdom
Battery drain after amp install
Hi guys,
Just installed a Mutant nw280sp amp and it was working fine when I installed it a few days ago.
I will freely admit that I don't use my Sei as often as I really should and when I tried to start her up this morning the battery was as dead as the proverbial doornail.
The multimeter confirmed that - even with the engine and headunit off - there was still power being channelled through the amp. Ideally I would get a better amp (since that one cost me less then £20). Would it be the amp itself that is causing the power drain, or have I perhaps missed something else along the way?
Cheers in advance
Eklipze3k is online now
Old 20-04-2008   #2
Ah. Not good...
chaos's Avatar
Trader Rating: (3)
chaos has donated! United Kingdom
Re: Battery drain after amp install
Are you sure that all power to the amp is cut when the ignition is off, i.e. the remote wire is wired correctly?
Chaos - Life wouldn't be the same without it.
Cinq parts clearout!
chaos is offline
Old 20-04-2008   #3
Hills are my enemy!
Eklipze3k's Avatar
Trader Rating: (0)
Yep, remote is wired correctly. Checked the voltage on that and 0 when HU off, 10-12 when HU on. However, that doesn't stop the main power line feeding power to the amp, which it then just channels to the ground.
Old 20-04-2008   #4
am4n's Avatar
Trader Rating: (0)
where are u taking the reading from? theres always going to be power at the + terminal of an amp unless u decide to put a switch in the wire
Work In Progress
am4n is offline
Old 20-04-2008   #5
Hills are my enemy!
Eklipze3k's Avatar
Trader Rating: (0)
Tbh it was a buddy of mine doing the testing so I'm not 100% sure where it was taken from, most likely the +ve terminal as he did suggest a switch. In that case though - as there were no problems prior to installation - what could have caused the power drain ?
Old 20-04-2008   #6
Andy Monty's Avatar
Trader Rating: (0)
Andy Monty has donated! United Kingdom
did your mate measure the voltage or amp draw? you are bound to have voltage at the terminal.. its if its actually drawing any current your going to have a problem
Andy Monty is online now
Old 20-04-2008   #7
Hills are my enemy!
Eklipze3k's Avatar
Trader Rating: (0)
Pass - I'll ask him tomorrow when I see him at work ... if I remember correctly (and my memory is sh*te) there was voltage but no current but I could be wrong ... and have been known to be on many occasions ...
Old 20-04-2008   #8
Andy Monty's Avatar
Trader Rating: (0)
that sounds right
when you was working on the sie putting the wiring in did you turn the courtosy light off? as a few hours with the doors open will drag the battery down and have you been showing off your sub with the engine turned off??
Old 20-04-2008   #9
Hills are my enemy!
Eklipze3k's Avatar
Trader Rating: (0)
When we were installing it the battery was disconnected, and it worked fine after installation. It's only a pair of 6x9's in the parcel shelf rather than a sub but no, every time i've used them (which is only twice since installation) the engine has been running
Old 24-04-2008   #10
Hills are my enemy!
Eklipze3k's Avatar
Trader Rating: (0)
Just FYI - it turned out the be the HU ... I hadn't bother doing the "switch on and off with ignition" and my laziness cost me the battery charge ... so that'll be getting done tonight!
Battery Drain Help Red1Leader Multipla 8 13-04-2008 19:49
I.C.E battery drain StiloRiding17's I.C.E 11 19-02-2007 00:47
(T) Battery drain barneyb Punto 6 22-08-2005 18:09
Battery Drain! mastermick70 I.C.E 10 23-05-2005 16:31
Help - battery drain vix92008 Ulysse 5 07-02-2005 08:20
