| Stereo Harness Connector Hey guys, I'm planning to upgrade my audio system with a sub, but I am eager to not modify any existing wiring so that I can completely remove everything if there are ever any problems (for warranty issues). I was thinking I could purchase a second harness for the back of the HU, and splice my wires into that. If I ever needed to remove the setup I could then just plug the old harness back in. So I am wondering if anyone can tell me how accessible the other end of that harness is? I.e. the opposite end to the one that connects to the HU? Thanks!
__________________ GP Sporting 1.4 16v Chemical Grey - Pioneer TS-WX11A under-seat 'stealth' sub | |||
| *custom name* | Re: Stereo Harness Connector just get a pc2-69-4 or pc2-04-4 from anywer, halfords stock them for 13 quid, and splice them as you please, if you want to upgrade your sound system buy a new unit, OEM ones arent that powerful anyway, one that has pre-outs meaning no cutting of wires, just simple connector blocks this means when you sell the car you can take your stereo with you and install the old one back in witout any problems btw i dont know if yours has an ignition feed and wer it is, i can soon find out if your stuck, that will determine the correct harness for you to get but they are all female to male iso plugs so if the wires dont run correctly, just cut them and crimp them the right way
__________________ 1.2 3dr stilo dropped on claws & a suzuki bandit v | ||
| | #3 | ||
| Re: Stereo Harness Connector Cheers for the advice & harness numbers j0nny. I'll check it out and let you know how it goes
| | #4 | ||
| Re: Stereo Harness Connector It looked a bit difficult to get to the other end of my harness connector to swap the entire thing out, so I have actually gone for a short female <-> male ISO connector block (PC2-36-4), which I will splice into and will act as a passthrough for the standard harness connector. A couple of the wires in this connector don't match up to my HU so I just need to swap a couple around. I am hoping it's gonna work great and it'll be real easy to remove if needed.
| | #5 | ||
| Got DISH? | Re: Stereo Harness Connector gp has no ign feed on that loom i had to make one from the cig lighter lol | ||
| | #6 | |||
You've already got yours sorted obviously, but for reference: http://www.fiatforum.com/i-c-e/13915...-headunit.html
__________________ GP Sporting 1.4 16v Chemical Grey - Pioneer TS-WX11A under-seat 'stealth' sub | ||||
| | #7 | ||
| *custom name* | Re: Stereo Harness Connector if your just using the OEM stereo them as long as the wires are running straight from ISO to ISO then the stereo will work perfectly. its rather clever, i think the recognise the illumination feed to light up the buttons to switch on but it should still switch on and off with the key despite not having an ignition feed
| Need an engine cable harness ECU connector | luximax | Multipla | 1 | 27-11-2004 18:30 |
| | luximax | Bravo / Brava | 1 | 22-11-2004 20:29 |
| Need a marelli iaw49 cable harness connector | luximax | Lets Talk FIAT | 1 | 22-11-2004 18:47 |
| | luximax | Marea | 0 | 22-11-2004 11:35 |
