The FIAT Forum
Go Back   The FIAT Forum > Miscellaneous > I.C.E
Old 06-03-2008   #1
radders112's Avatar
Trader Rating: (0)
Install Rear Speakers With HU
This is my first post so be gentle with me!
I have a Punto Mk2 with no rear speakers fitted as standard so i assume there is no speaker harness fitted at the back. I currently have installed 2 rear speakers by connecting them to the front door speaker then routing them through the floor towards the back.
What i would like to do is set up my HU so that i can set the fade to front/back and balance left/right. I have a pioneer deh-5700mp.
What would i have to do to get my rear speakers to do this?
Also i am planning on installing an amp in my car, is it worth wiring up both front door speakers or just go straight to the HU?
Radders
radders112 is offline
Old 08-03-2008   #2
Punto 1.1S (96)
Donut Boi's Avatar
Trader Rating: (0)
Donut Boi has donated! United Kingdom
Re: Install Rear Speakers With HU
Firstly wireing from your front door speakers is a big nono here is why
If your've wires + to + and - to - (which im gessing you have) this means that the impedance of the HU amp is reduced to 2ohm this is not very good for your HU and can couse it to over heat and become unstable
How To Fix
You need to run the wires from the back speakers to your HU then you need to find which is the two rear ouputs (on my sony its purple and purple/black for Right Rear then green and green/black for Left Rear) then just join them in
Hope This Helps Tom
If My Post Has Helped You And You Wont To Say Thanks Just Click The Thumbs Up Sign On The Bottem Right Of My Post Thanks
Donut Boi is offline
Old 09-03-2008   #3
radders112's Avatar
Trader Rating: (0)
Yeah, been workin on my car today and it seems that what you said can be done, thanks. Do you know where i can get the crimps/connectors so the wires can fit direct inside the iso block? I wanna make the car fitted with rear speakers so when i come to sell it, i can remove the cd player without having to cut any wires
Old 09-03-2008   #4
*custom name*
j0nny's Avatar
Trader Rating: (0)
j0nny has donated! United Kingdom
im guessing you just want the femaile mini blade that sits inside the ISO block, i havent seen anyone selling these seperatly, you can buy spare ISO blocks in any half decent audio place, if you know anyone theres always one lying about somewer, just remove the bits from inside it, but be careful, theres a wee bit of metal coming from it to hold it in place, best bet is to get a small fine object, even a needle and bend that bit down before removing
"its ok, at 100MPH the needle sits over the airbag light" lol
j0nny is offline
Old 09-03-2008   #5
Punto 1.1S (96)
Donut Boi's Avatar
Trader Rating: (0)
theres a few options 1 is j0nny another is you can push the wire threw the bk of teh ISO block and then connect it this will hold it in place but not reli to "profesional" or you can buy ISO blocks from any car audio place and wire it all in agen its up to you reli m8
Hope This Helps Tom
Tags: , , , , , ,
vB code is On
Seicento rear speakers k146 I.C.E 1 25-10-2007 23:40
Adding rear speakers to basic mk2 punto Zip I.C.E 6 17-09-2007 20:26
Punto mk2 rear speakers help! mannionmax Punto > Technical 0 30-01-2006 21:49
10cm Rear Speakers SCDaveT Punto > Styling 15 07-08-2004 22:42
Installation of rear speakers Mike-MK2 Punto 8 08-09-2003 04:00
