The FIAT Forum
Go Back   The FIAT Forum > Miscellaneous > I.C.E
Old 06-07-2004   #1
Trader Rating: (0)
pre outs
i've only got 1 pre-out on my headunit and wondered if i could use two amps? if i can use two , how do i connect them up?
MeAcHeM is offline
Old 06-07-2004   #2
taffy git
gaz.d's Avatar
Trader Rating: (2)
gaz.d has donated! United Kingdom
u could use 2 amps, by using splitters.
u run the pre-out from the headunit, then split and split again until all your connections are filled
Seicento Sporting, Modified Front Bumper, Saxo Custom Spoiler, Abarth Side Skirts, Bad Boy Bonnet, Afterburner Rear Lenses, 4" Powerflow Exhaust System, Abarth 14" Alloys.
IN THE PIPELINE:
-40mm Drop or Coilovers, New Front Bumper, Rear Splitter, New Mirrors (Not the cup ones[xx(], something different)
Check out my site http://badboygaz.mysite.freeserve.com
FIATForum stickers available PM me for details or see: http://www.fiatforum.com/forum/topic.asp?TOPIC_ID=10000
gaz.d is offline
Old 06-07-2004   #3
Trader Rating: (7)
Suriname
Alot of amps have pre-amp outputs so once youve connected your RCA leads to your first amp, you run a small RCA lead (readily available) from the pre-amp output to your new amp.
chrisunoman is offline
(G) Fuel tank filler vent blocked and cut outs Mazz0 Uno 8 02-06-2004 01:17
