The FIAT Forum
Go Back   The FIAT Forum > Miscellaneous > I.C.E
Old 24-02-2008   #1
jiggy's Avatar
Trader Rating: (0)
jiggy has donated! United Kingdom
Mono sound through both left and right speakers?
I've been planning to change my ICE for ages and this morning I finally got everything wired up but I didn't get the result I expected. Here's what I did.
I have a Sony head unit with a pair of aux out RCAs. One pair's for input I think so is unused. The pair I'm using has leads (red and white) going from here into my amp's RCAs (channel 1 input and channel 2 input).
The amp's set to 2 channel rather than 3 or 4.
From the amp I have channel 1 + and - going to my left crossover unit's input + and -. From the crossover I have attached the left side tweeters and woofers.
Also from the amp I have channel 2 + and - going to my right crossover unit's input + and -. From the crossover I have attached the right side tweeters and woofers.
So far so good, that's the way it should be set up right? When I play music with it set up like this all of the music is coming through both right and left speakers but it's in mono I think. What I mean is I'm getting all of the music and it's equally coming out of both speakers. When I go onto the head unit's controls and play with the balance it has no effect whatsoever - I can set it to all the way left or all the way right and I still get the same levels coming out of both speakers.
Is this a common mistake I've made? Anyone have any ideas where I might have gone wrong? Ways to diagnose the problem?
Many thanks
jiggy is offline
Old 24-02-2008   #2
Punto 1.1S (96)
Donut Boi's Avatar
Trader Rating: (0)
Donut Boi has donated! United Kingdom
Re: Mono sound through both left and right speakers?
i might b rong but my head unit has a front, back and sub RCA outs but my old head unit only hed sub out (mono) may b your RCA out is MONO for subs or may b there a setting on you HU to switch
hope this helps tom
If My Post Has Helped You And You Wont To Say Thanks Just Click The Thumbs Up Sign On The Bottem Right Of My Post Thanks
Donut Boi is offline
The following user says "Thank You!" to Donut Boi for this useful post:
jiggy (24-02-2008)
Old 24-02-2008   #3
Phil's Avatar
Trader Rating: (0)
Power amp could be running in bi-amp mode? (if its got one, this feature is designed for use when running one sub and combines both channels, to get the most power from the amp).
Phil is offline
Old 24-02-2008   #4
jiggy's Avatar
Trader Rating: (0)
Aha - from the manual I've just seen there's a a setting somewhere in the head unit's menu:
SUB/REAR
To switch the audio output
-"SUB-OUT" to output to a subwoofer
-"REAR-OUT" to output to a power amplifier
I need to go downstairs and check but I bet it's running in sub mode as suggested up there, as opposed to that REAR-OUT mode. Kind of obvious when I think about it - hopefully changing this setting will sort it
jiggy is offline
Old 24-02-2008   #5
jiggy's Avatar
Trader Rating: (0)
Yep that's fixed it. Except now I've got Left and Right wrong way round but that's no worries, just need to swap a couple of cables at the amp when I can be arsed
Cheers guys
jiggy is offline
Old 25-02-2008   #6
Punto 1.1S (96)
Donut Boi's Avatar
Trader Rating: (0)
glad you got it sorted m8
vB code is On
