The FIAT Forum
Go Back   The FIAT Forum > Miscellaneous > I.C.E
Old 21-02-2008   #1
Trader Rating: (0)
will these fit and recommendations?
hiya i have been reading the threads and found out that the mounting depth for the front speakers is not that big for a mark 2 punto sporting
while loking around i came across these speakers will these fit right in?
http://caraudiosecurity.com/shop/pro...s_id/4305.html
http://caraudiosecurity.com/shop/pro...s_id/6688.html
http://caraudiosecurity.com/shop/pro...s_id/6694.html
which ones would you recommend and has any one actually got these in the front how do they sound
i also want infinity refrence 6x9's
either
http://caraudiosecurity.com/shop/pro...s_id/6690.html
http://caraudiosecurity.com/shop/pro...s_id/3922.html
again which one would you recommend and has any one actually got these in the back?
also i would like to know of any 4 channel amps that could be used to power these?
thank you in advance for your help
ps if any one else has other 16.5cm components in the front of their mark 2 punto that fitted straight in please could they let me know cheers.
a_star100 is offline
Old 21-02-2008   #2
just can't get enough
toad101's Avatar
Trader Rating: (0)
toad101 has donated! United Kingdom
Re: will these fit and recommendations?
these are the ones i'd go for
any decent 4 channel amp would be fine
i wouldn't get the 6x9's if your going to be fitting a sub at a later date and spend more on the components
toad101 is offline
Old 22-02-2008   #3
Trader Rating: (0)
cheers with the amp is it best to match up rms values?
Old 22-02-2008   #4
Ah. Not good...
chaos's Avatar
Trader Rating: (2)
chaos has donated! United Kingdom
As a rule of thumb, yes.
Chaos - Life wouldn't be the same without it.
Cinq parts clearout!
chaos is offline
vB code is On
Hood fitting prices and recommendations doolahrock Barchetta 18 14-12-2007 13:26
Recommended soft top supply & fit B-vectis Barchetta 23 06-03-2007 08:52
Exhaust Recommendations ne1l Punto > Technical 3 07-02-2006 21:39
DVD-RW recommendations Liam Leisure Lounge 19 11-01-2006 01:17
Tyre Recommendations! NottsCharger Cinquecento / Seicento 17 03-10-2005 23:07
