| Fitting comps in Grande Punto wiring info pls Got some Infinity Ref comps to fit in the front doors. The factory wiring has a seperate feed to the woofer (lol) and tweeter, do I wire the woofer feed to the crossover and ignore the tweeter feed?
| Punto 1.1S (96) | Re: Fitting comps in Grande Punto wiring info pls new one on me depends how it works if theres no high sound going threw the woofer which i gess there not as there sperate so your standerd head unit much have a cross over already built in so id say your best wirering them in seprate, but dont hold me on it may be some1 els could shead some more light Hope this helps Tom
__________________ ![]() If My Post Has Helped You And You Wont To Say Thanks Just Click The Thumbs Up Sign On The Bottem Right Of My Post Thanks | ||
| | #3 | ||
| Re: Fitting comps in Grande Punto wiring info pls Update. The factory tweeter has a capacitor built in - I dont know enough about these things to know why so I decided against wiring the new tweeter to the existing ones feed wire. Instead I took the main speaker feed to the crossover then to the new comps. The tweeter is getting the highs, possible too much so will try the -3db on the c/over. Not sure about the woofer though, seems a bit muffled. I think there is two other ways I could wire them up - firstly use both the existing feeds together to the input on c/over and secondly connect the woofer direct to the main feed and route the tweeter feed through the c/over. These may be no-no's so advice please. Will go and start on other door now I've thawed out! BTW the head unit is the std Blaupunkt CD with Blue.
| | #4 | ||
| Punto 1.1S (96) | Re: Fitting comps in Grande Punto wiring info pls firstly i think you mean a resistor on the tweeters ![]() wireing both feeds may be the answer its should't drop the resistance that way even if the head unit hat the cross over built in both mid and triable would be going to the cross over and then the cross over would sort it out. Hope This Helps Tom
| | #5 | ||
| Re: Fitting comps in Grande Punto wiring info pls Thanks for input Donut Boi. It is definitely a cap - it says on one of them 4.7mfd which even with my limited electronics knowledge I think means it is a cap. Anyway I've left the wiring using the main feed to crossover. Now I've finished and played about with the bass & treble settings - wow!! What a difference. ![]() ![]() Next the rears? Thanks again.
| | #6 | ||
| Punto 1.1S (96) | Re: Fitting comps in Grande Punto wiring info pls nice to know you got it sorted m8
| | #7 | ||
| Re: Fitting comps in Grande Punto wiring info pls your right it is a capacitor.. Its intended to protect the Tweeter from "spikes" caused by the amp starting up for example by adsorbing excess voltage.. C = 1/2 (Pi) fZ C is the "safety" capacitor value in Farads (1 Farad = 1,000,000 mfd). f = one-half the tweeter crossover frequency Z = tweeter impedance at the crossover point
| | #8 | ||
| Re: Fitting comps in Grande Punto wiring info pls Thanks for confirming that I was right on that - now have to understand the rest of your info! ![]() Protect the tweeter - why? they're rubbish anyway (from China).
| | #9 | ||
| Re: Fitting comps in Grande Punto wiring info pls the tweeter is run off a cross over, Compared to a standard speaker it moves a tiny amount but rapidly to give you the High notes, When most Amps start up there is an initial surge of power that is normally heard as a POP though the speakers, this POP is a surge of power making the speaker move, normal speakers have the tolerances and range of movement to adsorb the surge but the Tweeters cant, the Pulse of power can make the tweeter element (aka Cone) detach and "blow" or repeated surges can fatigue the element effectively killing its sensitivity and sound quality.. You shouldn't have to worry about the formula as the component is usually supplied with its own cross over however its handy to know if your making a system out of various bits from different manufacturer's hope that helps (a bit)
| The following 2 users say "Thank You!" to Andy Monty for this useful post: | ||
Donut Boi (19-02-2008), knellerhall (19-02-2008) | ||
| | #10 | ||
| Re: Fitting comps in Grande Punto wiring info pls Thanks for that Andy Monty. You learn something new every day! It's having people like you on the forum that helps the rest of us get the help and advice we need - talking of which, and granted off thread, you posted the hack for the aux input I think. Going to give it a try but when I press the src button my Blaupunkt HU I only get CD (when one in) and tuner. So how do I get AUX?
| | #11 | ||
| Punto 1.1S (96) | Re: Fitting comps in Grande Punto wiring info pls may b a thanks in order for andy? i sent mine ![]()
| | #12 | ||
| Re: Fitting comps in Grande Punto wiring info pls Done - a bit new to this forum thing!
| | #13 | ||
| Re: Fitting comps in Grande Punto wiring info pls thanks for the thanks chaps knellerhall To get to the AUX mode you need to press the cd button twice or scroll through the menu via the SRC button on your steering whee it goes something like FM AM CD AUX then back to FM Will put some more info up later im going out for a bit..
| | #14 | ||
| Re: Fitting comps in Grande Punto wiring info pls [ You will want screened cable as the AUX input picks up the noise of the coil pack/ Alternator, keep it as short as you can as there is quiet a drop in sound level with a long run of cable. Im thinking of putting a small modular pre-amp in line between the 3.5mm jack and the AUX input but thats an idea for the summer me thinks (2 of these http://www.maplin.co.uk/module.aspx?...&doy=20m2#spec )
| | #15 | ||
| Re: Fitting comps in Grande Punto wiring info pls Tried the src button but no AUX, however reading my manual (theres a first!) my HU is CDC compatible and it says it will only show 'changer' when one is fitted. No mention of AUX. So I guess the unit 'senses' when a load is detected? Do you think it will still work with an MP3 connected to the pins? Just to fill you in I also have bluetooth in the HU as well.
| How many Puntos are there on the Forum? - The Thread | FiatStiloJTD | Punto | 543 | 06-06-2008 16:15 |
| NEWS: Fiat Grande Punto Official Press Release & Photos | Steven | Grande Punto | 80 | 02-11-2005 16:12 |
