The FIAT Forum
Go Back   The FIAT Forum > Miscellaneous > I.C.E
Old 26-01-2008   #1
just can't get enough
toad101's Avatar
Trader Rating: (0)
toad101 has donated! United Kingdom
amp wireing
i have this amp http://cgi.ebay.co.uk/Infinity-Refer...QQcmdZViewItem running off a 8 gauge cable would i be better off replacing the cable with 4 gauge, iirc the amp has two 80amp fuses
toad101 is online now
Old 26-01-2008   #2
Ah. Not good...
chaos's Avatar
Trader Rating: (3)
chaos has donated! United Kingdom
Re: amp wireing
160A? Through 8awg? Are you mad?
That's 0awg territory.
Personally 80A would be the most I would put through a 5m run of 4awg.
Chaos - Life wouldn't be the same without it.
Cinq parts clearout!
chaos is offline
Old 26-01-2008   #3
toad101's Avatar
Trader Rating: (0)
Re: amp wireing
i guess i should upgrade the wireing then
i have a 60amp fuse fitted at the batt and the distibution box at the moment
Old 27-01-2008   #4
toad101's Avatar
Trader Rating: (0)
Re: amp wireing
just checked the amp, the fuses are 30 not 80
Old 28-01-2008   #5
Ah. Not good...
chaos's Avatar
Trader Rating: (3)
Re: amp wireing
4awg would be sufficient then
chaos is offline
The following user says "Thank You!" to chaos for this useful post:
toad101 (28-01-2008)
Old 28-01-2008   #6
toad101's Avatar
Trader Rating: (0)
Re: amp wireing
was getting worried as i had trouble getting 8 gauge through the bulkhead and 0 gauge is alot thicker
(T) Still got problems with amp wireing! Stemondo Stilo 4 08-08-2005 11:31
Guide: How to wire an Amp Luke I.C.E 3 11-07-2005 18:33
Amps – The difference between all. Luke I.C.E 4 20-06-2005 15:29
