The FIAT Forum
Go Back   The FIAT Forum > Miscellaneous > I.C.E
Old 14-01-2008   #1
moe86's Avatar
Trader Rating: (0)
fitting a door speaker/are jvc speakers good?
Hi everyone, i have a 5dr mk2b punto & i installed a jvc kd-g385 head unit (5x4),lookin' to add 2 rear speakers (propably 350w) instead of the 30w factory ones & replace the 2 front doors speakers latter.
I have some questions here:
1- When i'm gonna replace the door's speakers do i have to remove the whole "door interior" or just the plastic cover that covers the speakers ?
2- without an amp, what "watt" power can i get from a 350w rear speakers?
3-Are jvc speakers any good ? i found that they're much cheaper than other rivals as kenwood ?
thanx alot
moe86 is offline
Old 14-01-2008   #2
More ICE Please
volxstu's Avatar
Trader Rating: (0)
volxstu has donated! United Kingdom
Re: fitting a door speaker/are jvc speakers good?
thanx alot
Right the speaker covers do come off but there is a plastic bit at the bottom that often snaps im sure a punto owner will be able to tell you exactly gow to get them off as when i had a punto mine were snapped when i got the car.
From your head unit as that is acting as the amp which gives the speaker the power you will get about 12w rms each from the headunit. The speakers themselves are realistically going to be 90-100w RMS which is far less than the 60w Rms per channel that you average 4 channel amp will give.
Originally Posted by Tris Harris View Post
I have tried to stay on here incase anything remotely interesting popped up me...
a chocolate finger sounds good
volxstu is offline
Old 14-01-2008   #3
moe86's Avatar
Trader Rating: (0)
thanx volxstu, i guess this means i do really need an amp.
still lookin' for any experiences about jvc speakers & amp since they're relatively cheaper than many other brands
moe86 is offline
Old 28-01-2008   #4
moe86's Avatar
Trader Rating: (0)
so, i've bought the 500w 5 way jvc speakers for just 400 L.E (around $67) , now i'm gonna change the front door speakers with a 200w 4 way ones, but i still don't know which amp should i get ?? should i get a 700w one( 500 + 200 ) ? what does the "2-channel" or "4-channel" mean ? what's the difference between the "Bridgeable" & the other types ?
thanx everybody here
moe86 is offline
Old 03-03-2008   #5
moe86's Avatar
Trader Rating: (0)
Hi there,
still confused, what amp should i buy ? should it be a jvc too for better sound?
what watt power should it be if i'm using 500w + 150w speakers ?
thanx
moe86 is offline
Old 05-03-2008   #6
paulbfd's Avatar
Trader Rating: (0)
paulbfd has donated! United Kingdom
You need an amp which matches the RMS rating of your speakers.
Your 500w speakers will be peak power, more than likely 150wrms, so look out for an amp that does around 150wrms.
Black 100HP
Alpine CDA-7944, PXA-H701 processor and RUX-C701 controller.
Hertz Mille MLK2 components, Mille 10" subwoofer and HP4 amplifier.
Chord Epic speaker cable and Anthem RCA leads.
paulbfd is offline
vB code is On
Recommend good speakers? luminous Punto 1 12-03-2005 23:00
Speakers! markwartd Punto 5 28-02-2005 12:58
Complete Noob needs advice on speakers... quarryman I.C.E 5 07-01-2005 11:23
Fitting Front Speakers Dan_55 I.C.E 3 22-12-2004 21:54
Fitting Front Speakers marky_20 Punto > Styling 7 24-05-2004 19:17
