The FIAT Forum
Go Back   The FIAT Forum > Miscellaneous > I.C.E
Old 22-12-2007   #1
Trader Rating: (0)
Switched live feed for head unit
Morning
Another quicky, hopefully.
I've just replaced the head unit, and checked all cables etc are original and they seem to be. All connectors fit fine, and the ISO connector appears to follow standards (it's a Blaupunkt Sevilla HU). I can't see any obvious signs of any previous owner's bodged attempts with snaplocs or whatever...
However, the HU won't switch off with the ignition, as the power feed seems to be continuous, and the HU has to be switched off manually.
Before I rip out the dashboard...
1. Is this normal for a Punto?
2. If not, any advice on how I can make it 'switvched' with the ignition?
Thanks in advance
JB
Joybringer is offline
Old 22-12-2007   #2
Veracocha
bozzy's Avatar
Trader Rating: (3)
bozzy has donated! United Kingdom
Re: Switched live feed for head unit
I believe it's a common thing with most Fiat's. Makes you think about removing the front panel though.
Alternative is find a feed from something that comes on with the ignition, somebody did it with their door button lights I believe.
bozzy is offline
Old 22-12-2007   #3
*custom name*
j0nny's Avatar
Trader Rating: (0)
j0nny has donated! United Kingdom
most fiats dont come with an ignition feed, so the only way to get a stereo working without adding extra wiring is to keep it on a permanent live, the frustrating thing about this is that it doesnt know when you switch the car on/off so you have to switch it on and off manually. youre best bet is to get an ignition feed from any appliance that switches on with the keys, easiest one is probably the cigarette lighter so run a wire from the live terminal in this to the ignition feed on the stereo and that should do it alright
1.2 3dr stilo dropped on claws & a suzuki bandit v
j0nny is offline
vB code is On
CD Head Unit Wiring Issue Fordy_C Cinq/Sei > Technical 10 07-12-2006 11:05
Connect Nav+ Installation Rich Stilo Guides 0 23-07-2006 13:00
MK2b Head Unit - install problems - HELP Please Punto_Lassie Punto > Technical 5 08-08-2005 22:49
head unit loosing power after engine off Bushboy I.C.E 4 23-06-2005 17:22
New Head Unit Problems - Help Required Punto_Lassie I.C.E 5 16-10-2004 15:05
