Thread Tools
Old 25-09-2007   #1
Anfield has donated!
How to wire up a sub into my car?
Im buying a amp and a sub for the first time and im wondering how to wire up the the sub into my sound system. Would it be ok to just link it up to the rear speakers or is there a better way to do this like going directly into the connecting block behind my headset bit?
Anfield is offline Reply With Quote Quote
Old 25-09-2007   #2
Status: DEFCON Grumpy
custard's Avatar
Trader Rating: 1
custard has donated!
Re: How to wire up a sub into my car?
sorry not sure what you mean.
what amp are you getting? 2 channel,4??
what head unit do you have?
Old 25-09-2007   #3
i have a Kenwood KDC-W3037A CD Player
Fusion EN-AT110 and it has a built in amp
Old 28-09-2007   #4
dead easy to wire up. you don't say if you've purchased an amp wiring kit yet, i'll assume you have because your gonna need one anyway.
1: Find the thick red cable in you wiring kit and find a suitable grommet in your blukhead (engine compartment into vehicle cabin) if you cannot find one it is allowed to drill a hole, but use a grommet to stop any future fire hazards and remove swarf. This will supply your amp with a live from the battery, the fuse should be mounted close to the battery. Do NOT connect to battery yet
2: Remove sill trims or if your feeling professional today, the passenger seat too.
3: Remove head unit and locate the pre-outs or signal out sockets (red and white, marked L & R) and also the blue wire labelled 'ant rem' or something I think on the kenwood loom. Plug the pre-out cables from your kit into the appropriate sockets in the headunit and crimp on or attach the thin blue wire from your kit to the blue wire from the back of your headunit.
4: Route the preoutcable and blue switch on cable (remote) to the boot.
5: Route the live cable to the boot, at least 6 inches away from the preout cables or you get interference from the alternator.
6: Remove some of the boot trim to find a suitable bolt that goes into the body of the car, use a sharp screwdriver or again if your feeling professional use a wire wheel in a drill and remove some of the paint around the removed bolt, connect the ring end of your thick black earth cable (from your kit) to this and the other end to the amplifier. Connect your live up to the +12 or +ve socket on the amp, hook up the remote to the REM or S/O socket and plug your preout connection in. Hook up the battery connection and check the amp powers up without the protection light when you switch the headunit on.
The Kenwood 3037A only has enough outputs for a 2 channel amp, so you will need to use Y- preouts if it is a 4 channel amp.
Aidan is offline Reply With Quote Quote
Old 28-09-2007   #5
i got my sub/amp and power cap fitted for 40 if u dont feel adventerous
ive done it myself before twice...anndd its a bit of a ball ache.
u need to do as above ^^
u cant just run your sub through your rear speakers, your amp has RCA cables which carry the sounds to your sub! remote cable (usually blue & really thin) turns off your amp when u switch off your ignition.
black = earth (simple really) and Red is power!
if u do wire yourself remember put your RCA cables down one side of the car & power and remote cable down the other side, this stops interference.
http://www.ehow.com/how_3680_install-car-amplifier.html this website might help. when your system is wired...put on your best track & wind it up!
http://www.fiatforum.com/gallery/dat...9092007036.jpg
Simple Yet Affective looking Punto...
No, its not a 5dr family car
Cowelly is offline Reply With Quote Quote
Old 01-10-2007   #6
More ICE Please
volxstu's Avatar
volxstu has donated!
Quote Originally Posted by Cowelly View Post
This is an ICE section on a forum your not supposed to discourage willing new people from doing things themselves.
If your into this sort of thing then learn how to do it from those on the forum.
Car Audio Goodness at its best for sale.
http://www.fiatforum.com/classifieds...?product=28141
volxstu is offline Reply With Quote Quote
Old 01-10-2007   #7
custard's Avatar
Trader Rating: 1
Quote Originally Posted by volxstu View Post
this is the thing.someone asks is X hard to do?
for some its easy and others a nightmare.
to me wiring in a sub and amp is a fairly by the numbers thing but others its like thumb brain surgery
however most of the time it doesnt hurt to try
Old 02-10-2007   #8
More ICE Please
volxstu's Avatar
Quote Originally Posted by custard View Post
From their first post they were asking what they need to do giving the impression that they are willing to give it a go. I feel that this should never be discouraged. Mainly for personal satisfaction, something created by yourself is always better than something fitted by sumbody else. Its a bit like a free Pint tastes better than the one you paid for.
Old 02-10-2007   #9
custard's Avatar
Trader Rating: 1
spoken like a true scot
Old 02-10-2007   #10
More ICE Please
volxstu's Avatar
Shame im from south east England but anyhoo nothing wrong with being a Scott for a day.
Old 08-10-2007   #11
Geek of the Week
smokeyjoe03's Avatar
Trader Rating: 1
smokeyjoe03 has donated!
Aniki Pingpong Champion, Rat Zapper Champion, TIE Fighter Shooter Champion
Yeah basically all of the above.
You can't use the built in amp from the HU because it won't output enough power. Your best bet is to go for an amp and sub package as these also come with wiring kits too.
If you wanna go second hand I would recommend it as I got a whole mutant system for £80 nd all my mates are in awe of it.
As for fitting it, it depends how handy you are? all you really need is a screw driver and some patience.
I fitted mine myself and when I 1st turned it on I felt a great sense of accomplishment and saved about £50 too. Its worth having a go and if you muck it up then you still have the option of having it done for you.
Just follow the guide in the guide sectiona nd come back if you get stuck. I'm not really electric savvy but I managed it in 1/2 an hour and the info on this forum is infinately handy. Give it a go
smokeyjoe03 is offline Reply With Quote Quote
Thread Tools
(G) Getting wire from car into doors bodders Bravo / Brava 11 09-06-2006 23:40
(G) That didn't take long..................... spacecowboy Punto (Mk2/2b) 50 12-07-2004 16:41
(G) service centre sucks!!!!!! fulcrum Ulysse 14 12-05-2004 21:16
