The FIAT Forum
Go Back   The FIAT Forum > Miscellaneous > I.C.E
Old 24-09-2007   #1
Smally's Avatar
Trader Rating: (0)
Smally has donated! United Kingdom
jl distortion.
Hi i fitted my jl xr components into my grande punto yesterday the magnets wur to big so i spaced them with bolts and used 3 self tapping screws.
Bit of a bodge so i now am paying for it with distortion when i have any bass,
so can i just use foam (like you lie on when camping) cut out rings and build it up around the speakers until it is far enough out and clamp it down?
Or will this not work either any advice will be verygreatful.
Smally is offline
Old 24-09-2007   #2
just can't get enough
toad101's Avatar
Trader Rating: (0)
toad101 has donated! United Kingdom
Re: jl distortion.
do this but using mdf
toad101 is offline
Old 25-09-2007   #3
Ah. Not good...
chaos's Avatar
Trader Rating: (3)
chaos has donated! United Kingdom
Re: jl distortion.
You'd get better results from using birch plywood or steel though
Chaos - Life wouldn't be the same without it.
Cinq parts clearout!
chaos is offline
Old 25-09-2007   #4
paulbfd's Avatar
Trader Rating: (0)
paulbfd has donated! United Kingdom
Re: jl distortion.
10% equipment, 90% install.
XRs are fantastic components and should be mounted properly and not bodged.
Like Toad says, mount them to an MDF baffle which is firmly secured to the door. It needs to be well sealed from the back and really, really solid.
Also if you can, apply some sheets of Dynamat to door and try seal the any holes in the door behind where the door card is, makes a huge difference.
Running the XRs off a headunit amplifier is also a waste, get some real power up them so they sing.
Black 100HP
Alpine CDA-7944, PXA-H701 processor and RUX-C701 controller.
Hertz Mille MLK2 components, Mille 10" subwoofer and HP4 amplifier.
Chord Epic speaker cable and Anthem RCA leads.
paulbfd is offline
Old 25-09-2007   #5
paulbfd's Avatar
Trader Rating: (0)
Re: jl distortion.
Hell yeah.
Black 100HP
paulbfd is offline
Old 25-09-2007   #6
Smally's Avatar
Trader Rating: (0)
Re: jl distortion.
Ok i will do that and i have a hifonics amp so its not running off the HU's power. It was tricky to run the wires through into the the door but i got there in the end!
Smally is offline
Old 25-09-2007   #7
paulbfd's Avatar
Trader Rating: (0)
Re: jl distortion.
Cool. Should be a stunning front end once you've got it fettled Smally.
Black 100HP
paulbfd is offline
Old 25-09-2007   #8
Smally's Avatar
Trader Rating: (0)
Re: jl distortion.
Ok i will tell you what i have as i have ran out of ideas for more stuff.
I have an infinty basslink t sub
a Clarion DXZ858RMP HU
a Hifonics ZXi 4406 amp powering the front jl xr components.
so what shall i do get some jl's for the backs or leave it?
Smally is offline
Old 25-09-2007   #9
paulbfd's Avatar
Trader Rating: (0)
Re: jl distortion.
No speakers in the back, sell the basslink and power a 10" sub (the JL 10W3 would be ideal) from a pair of channels bridged on your Hifonics.
Stonking setup that, the Clarion is a nice sounding HU to I believe.
Black 100HP
paulbfd is offline
Old 25-09-2007   #10
Smally's Avatar
Trader Rating: (0)
Re: jl distortion.
yea prob a better sub is needed but my sub fits perfect and takes up no room is there no really good subs that take up hardly any room?
Smally is offline
Sound Distortion Mr_noir_1976 I.C.E 7 03-06-2006 13:04
Distortion :( ne1l I.C.E 7 19-05-2006 02:52
Rattles and distortion! help! copeland666 I.C.E 8 09-12-2005 13:43
(G) mk1 punto speakers, distortion beau Punto 4 18-01-2005 23:29
mk1 punto speakers, distortion! beau I.C.E 1 23-12-2004 00:37
