topcat5 Established member Joined Nov 19, 2006 Messages 268 Points 160 Location The Honest Toun Apr 22, 2016 #1 Set (positive & negative) for a 2001 1.9D Doblo. Required.
V varesecrazy Patron member Written 10+ guides Joined Apr 27, 2011 Messages 34,950 Points 7,825 Location Near the M4 Apr 23, 2016 #2 did you get prices from the forums supported stockists..?? would've thought they'd still be available without issue.. Charlie
V varesecrazy Patron member Written 10+ guides Joined Apr 27, 2011 Messages 34,950 Points 7,825 Location Near the M4 Apr 27, 2016 #3 topcat5 said: Set (positive & negative) for a 2001 1.9D Doblo. Required. Click to expand... I went into a local motorist shop today ( Headington Auto Parts - Oxford), and amid all the blister packed , bolts, fuses, etc were round pole battery terminals ( self-crimp), may be worth a try.., as probably a LOT cheaper than new built leads..,
OP OP topcat5 Established member Joined Nov 19, 2006 Messages 268 Points 160 Location The Honest Toun May 2, 2016 #4 I had a further look at both clamps and the plastic parts were restricting clamping. I broke them off and all was good again.
