| | Dashboard lights switch my car on earlier, and all the lights on the dash came on, the fuel light was flashing and no gauge was working.. city steering button light wouldn work, stereo say 'cancheck' several switch on/offs wouldnt fix it.. after 10 mins of being off, it came back to normal.. switched off.onn several times, nothing.. aanyone?
__________________ 1.2 8V GP in X-Over Black with Shogun Body kit. Custom built centre box and exhaust with twin pipes. 17 inch WolfRace Katana 2 alloys. Lowered on Eibach 30mm. Sevic 7.5 touch screen dvd player, Vibe Black Ice sub, Vibe Slick A7 amp. MTX components.. UniqStyling.co.uk | ||
Posts: 23,504 Thanks: 713 Trader Rating: 0 | Re: Dashboard lights CAN communication error or software 'glitch',get it to dealer to check.
__________________ | ||
| | #3 | |||||
Posts: 94 Thanks: 1 Trader Rating: 0 | Re: Dashboard lights
| | #4 | ||||||
__________________ http://www.xs4all.nl/~bvdam/temp/teddysig.png
| | #5 | |||
![]() spose i could get fiat to flash it right?
__________________ 1.2 8V GP in X-Over Black with Shogun Body kit. Custom built centre box and exhaust with twin pipes. 17 inch WolfRace Katana 2 alloys. Lowered on Eibach 30mm. Sevic 7.5 touch screen dvd player, Vibe Black Ice sub, Vibe Slick A7 amp. MTX components.. UniqStyling.co.uk | |||
| | #6 | ||||||
I heard that some people with this problem had a connector problem at the EC..computer (damn how is that thing called T14086?) Like it wasn't fitted right in the socket or something like that.
| | #7 | |||
Yep disconnecting battery will normally cure this,if not there is a flash available but think its for the 188 puntos...would need to check.
__________________ | |||
| | #8 | ||
| | Re: Dashboard lights This problem? ![]() ![]() I drove it to the dealer with no instruments, which was weird to say the least. Didn't take them long to fix and they said it was a loose earth cable. So I was happier than a pig in s**t cause it wasn't serious .
__________________ ![]() Present: 05 Punto Sporting 1.4 16v & R Plate Fiat Coupe 20VT ![]() | ||
| | #9 | ||
| Join Date: Jul 2006 Location: in the darkest corner of Africa!
Posts: 42 Thanks: 0 Trader Rating: 0 | Re: Dashboard lights I had the same today (week and a half old car) drove home, opened gate drove inside, turned car off and left key in ignition, went to go close gate and the radio turns on and starts playing, all back to normal
__________________ "FIAT | Driven By Passion" Past : UNO Pacer SX, UNO TURBO, PALIO 1.6 16v EL - Super-Charged 146kw Current : Grande PUNTO 1.4 DYNAMIC Crossover Black | ||
| | #10 | ||
Posts: 800 Thanks: 1 Trader Rating: 0 | Re: Dashboard lights What actually causes it?
| | #11 | ||
Posts: 23,504 Thanks: 713 Trader Rating: 0 | Re: Dashboard lights magic pixies no its just a software error,generally happens to new cars...there is a flash available but think its for the 188 puntos...would need to check....which I forgot to do today
| | #12 | ||
Posts: 23,504 Thanks: 713 Trader Rating: 0 | Re: Dashboard lights Software update for body computer available.
| | #13 | ||
Posts: 3 Thanks: 0 Trader Rating: 0 | all dash lights stay on after ignition turned my wife started her 06 plate grande punto this morning all the dash lights stayed on the car turned over ok but the indicators etc would not work,this happened once a few months ago but a lock/unlock and turning the ignition over cleared it previously but not this time has anyone had this happen to them,booked in the local fiat dealers but cant look at till thursday
| | #14 | ||
| | Re: all dash lights stay on after ignition turned Hi, This happened to me when I had my GP Sporting. Did it say 'CANCHECK' on the stereo?. It was a loose earth lead.
| | #15 | ||
| | Re: all dash lights stay on after ignition turned depends on the car spec level if you get the "cancheck" message.... Its a know fault/ problem as a tempory stop gap pop the bonnet remove the earth clamp (its quick release) and leave it disconnected for 5- 10 minutes this should reset the body computer.... there is a software update for this error and mine hasn't done it since i had it done so ring the dealers and get it booked in IIRC it can be done whilst you wait..
| | superfestiva | Marea | 9 | 28-07-2009 07:04 |
| | heavybds | Punto | 2 | 04-08-2006 19:24 |
| | fionaarm | Bravo / Brava | 1 | 08-04-2006 17:04 |
| | swana1976 | Punto | 6 | 16-11-2005 18:38 |
| | Chas Uno | Uno | 3 | 03-08-2005 00:07 |
