Been using this to monitor things for a while, wondering how accurate it is?
Highest boost pressure I've seen is 13.4 psi, once. Usually no more than 12.9, sure it should record 14 psi.
Coolant temp seems to be between 75 and 77C unless idling for a prolonged period then it will reach about 89c and fan kicks in. Mid 70's seems kind of low too.
Battery voltage is generally 14.0 v, also seems a little low.
Does the app generally read a little low or are the values normal or should I investigate these readings further?
Ben
Ben
