Hi All,
Fitting a decat pipe and 200 cell cat under car in the next few weeks and will need to lengthen the downstream O2 wiring harness and not sure how to go about it.
I've read that the cable is stainless or something else exotic that will not solder easily and, that it should not be soldered regardless as the sensor draws air through the cable for reference.
I know I could get a spacer and leave sensor in original position to get around EML but I'd rather have it post cat as it should be so I know the cat is doing what it should.
Any pointers appreciated.
Ben
Ben
