Thread Tools
Old 1 Week Ago   #1
Grande Punto 1.2 starting problem
Hi
So I went to start the car this morning and got nothing just lights on the dash including immobiliser, steering, ABS ect and a small clicking from the engine bay. I tested the battery and its fine then I connected a jump lead between the earth on the battery and the engine and tried again and it started. ECU earth on top of the engine looks good. Any suggestions tahanks
Mikey88 is offline Reply With Quote Quote
Old 1 Week Ago   #2
Re: Grande Punto 1.2 starting problem
Should I replace the earth strap from the gearbox???
Old 1 Week Ago   #3
DGPunto has donated!
Definitely check the cables, including under the plastic sheathing. Likely you have a bad terminal and/or corrosion in the cable
Pretty normal GP issue unfortunately
Thanks Mikey88 thanked for this post
DGPunto is offline Reply With Quote Quote
Old 1 Week Ago   #4
FIXED IT!
Basically the earth cable from the gearbox had pretty much snapped at the point where it bolts to the body before the battery, went to Halfords bought a earth cable for a fiver bolted it in and job done.
Thanks Bernievarian thanked for this post
Likes oldmanhouse, Bernievarian liked this post
Old 1 Week Ago   #5
Belgium
Thanks for the update Mike and congrat for job well and quickly done !!
BRs, Bernie
Thread Tools
(G) Grande punto starting problem BooBu Grande Punto 4 12-07-2017 13:01
(T) Starting problem grande punto 1.9 08 rossul Grande Punto 24 07-08-2012 17:04
(T) Grande Punto diesel starting problem JoeRichardson Punto (Mk2/2b) 3 26-04-2010 23:42
(T) Grande Punto Starting problem Grunter16 Grande Punto 9 18-11-2009 09:32
