Technical Change original radio for other original radio
Do you need help unlocking your radio?
Get your code instantly using our radio unlock service 🎵
01Mac
Hi everybody.
I change my original radio Blaupunkt model Fiat 199 CD (7 645 352 316) for another original radio Blaupunkt model Fiat 199 CD SB05 Uncolored vers (7 646 327 316) to have an aux input in the car and the bluetooth and the buttons on the wheel stay working.
My problem is that with the new radio, the SB05, the buttons on the wheel works but the aux input and the bluetooth doesn't. The bluetooth connects but when there are a call the radio don't make mute and the call don't sound in the loudspeaker.
Any idea how to solve it? in case that the new radio doesn't mach with my car, someone know which model does?
I have a 2006 Fiat Grande Punto.
Sorry, but I cannot answer your query, but it is similar to a query I have.
I recently purchased a Grande Punto 1.6D Sporting.
A previous owner has replaced the standard radio with a Sony head unit.
My Blue&Me is not working.
It just beeps at me, but nothing happens.
Sometimes if you say a command, the display will show "Searching" but nothing further happens.
Question - Would changing the radio for a non-standard unit affect the Blue&Me?
The steering wheel stereo controls also do not work, which is annoying, but I assume that is simply to the way they have wired it in.
If you want to have a chance of working go back to the stock HU.
Steering wheel controls will not work as well as blue& me .. it is probably not connected to the HU ... but even if it is possible to connect it a doubt it will work 100%.
