Technical anyone with 1.3jtd please check
hello, i found a connector that isnt connect to anything, but im not sure if it was always like that or if i exedently disconected it yestrday.
pics on where the start is located. and onwords.
open hood, locate tubine
[/url][/IMG]
next to the turbine there is is a wirecover splitting into 2 pieces, the unmarked one goes into a connector just a few centimeters of. where does the 2nd (marked) wire go and connect? can anyone please check on their 1.3 to see where it conects.
[/url][/IMG]
my is just sitting like this behind the battery tray...
[/url][/IMG]
ty
Looking at the loom diagram it's either K036 water temp sensor or K046, RPM sensor ...
BRs, Bernie
worth mentioning my is a mk2b.. but since gp has same engine i wanted to try here to. hmm bern do u have that diagram for mk2b? i cant find it...
by the lenght of the cabe ad asume its ko46, but rpm work fine? i think.....i drove like 10miles no problem. still dont know where the conector is, im checking the side of the engine and everything is conected, .. thats why id need someone with this car to manualy search for it..
im pretty sure its ko46, but the wiring loom splits into 2 sections again, one going into rpm senzor(ko46) and the other one is the one i have problems with haha
