Thread Tools
Old 4 Weeks Ago   #1
France
Question Changing the alternator belt
Hello people,
My Alternator belt just snap :/
I would like to change it by me own.. is it difficult ?
Did you know any tutorial ?
If i go to a garage what should be the price ?
Thank you
JamesPtg is offline Reply With Quote Quote
Old 4 Weeks Ago   #2
Belgium
Re: Changing the alternator belt
Hi James,
- lose the tensioner (relief the pressure from the spring)
- slip the new belt in place
- release the spring that loads the tensioner
- you're done ...
Easyer if you get 3 or 4 hands ;-)
BRs, Bernie
If someone here helpes You fix -orbetter, understand- your issue, hit the thanks icon @ bottom right corner, it's free and makes us feel helpy ;-)
Old 4 Weeks Ago   #3
France
Thumbs up Re: Changing the alternator belt
Thank you Bernievarian,
Did you have any picture/schema of the tensioner ?
Can do all of that from the top or I have to go under the car also ?
Old 4 Weeks Ago   #4
Moderator
g8rpi's Avatar
g8rpi has donated!
Quote Originally Posted by JamesPtg View Post
You don't say what engine you have, but normally you can do it from above and through the wheel arch (take plastic liner out).
This guide to a 1.2 cambelt change shows the fan belt, it has to come off before the cam belt). Obvisoly you do not have to do all the sensor and cam locking stuff relted to the cam belt.
http://www.fiatforum.com/grande-punt...placement.html.
If you have a different engine search the guides for the same engine, possibly in a different model.
Robert G8RPI.
g8rpi is offline Reply With Quote Quote
Old 4 Weeks Ago   #5
everson38 has donated!
I asked about this and got some.help from berne with regards to a pic. If u look through my posts it should be in there. It's a diagram from an actual elearn source
everson38 is offline Reply With Quote Quote
Old 4 Weeks Ago   #6
PuntoR60SX has donated!
Just to add to what's been said above (as for once I happen to have my Haynes manual to hand) -
The following is true for the 1.2 & 1.4 petrol models, not sure about the other engines.
If you have air con then there will be a tensioner - this can be rotated against the spring pressure using a 13mm spanner or socket to slacken the belt enabling it to be removed. Once the new belt is on it will maintain the correct tension automatically.
For models without air con there is no tensioner. Slacken the mounting bolts on the alternator to remove the belt. On refitting, move the alternator back to its previous position to take the slack from the belt. Manually check the tension using this method: applying firm thumb pressure there should be approx. 5 mm of free movement at the mid-point between the pulleys. Adjust the position of the alternator if this isn't the case.
Quote Quote:
I had one changed on a Mk1 Punto at my local independent garage not so long ago for less than £40 - probably 1/2 hour labour + parts. A friend had the same job done on a Toyota for a similar price (different garage). If in doubt phone round for a few quotes.
Likes everson38 liked this post
PuntoR60SX is offline Reply With Quote Quote
Old 4 Weeks Ago   #7
Quote Originally Posted by everson38 View Post
http://www.fiatforum.com/grande-punt...ml#post4278552
Old 4 Weeks Ago   #8
France
Question Re: Changing the alternator belt
Thank all of you for your answers !
I don't know which engine it's is because he as been changed but here a picture if it's helps.
I will check those link's (thank you)
If I ask a garage to do it how long this should take them ? 1 hours max ?
Old 4 Weeks Ago   #9
I would say it's definitely the 1.2 ... or the 1.4 ...
No sign of an air con unit.
Quote Quote:
I'd hope so.
Old 4 Weeks Ago   #10
Belgium
Yep, petrol for sure, no AC for sure, and quite a mess... for sure ;-) The tensioner is the alternator...
Procedure: (thanks to PuntoR60SX)
- losen the alternator
- slip the belt in
- tighten the alternator to remove belt' slack
BRs, Bernie
Thanks JamesPtg thanked for this post
Old 4 Weeks Ago   #11
France
I have to drive a little bit (~2km) to put my car into my garage and then process.
Could I drive without this belt ? I think she is not linked to the cooling system ?
Thank's again for your's useful post
Old 4 Weeks Ago   #12
Belgium
Hi James,
water pump's usually driven by the cambelt; but that all dépends on what engine is actually installed...
BRs, Bernie
Old 3 Weeks Ago   #13
Quote Originally Posted by Bernievarian View Post
Hi James,
BRs, Bernie
Just thought I would put up pictures of the other variation which has a tesioner on it.
The first two pictures are from the top of the engine and the last one is from underneath the car. I was trying to loosen the tension to just test it nut I wasn't sure which way to go and did not want to break anything. If anyone can tell me which way you turn would be great.
ID:	183849Click image for larger version
ID:	183850Click image for larger version
Old 3 Weeks Ago   #14
Belgium
The tensioner is pushing the belt so its 'dead' path is kept tight, you'll have to release the spring pressure to be able to remove the old belt and to put the new one in place, should be obvious in which way when you see the all thing...
Brs, Bernie
Old 3 Weeks Ago   #15
Hey guys apologies to always be that guy asking about brands etc but I have heard choosing wrong brand of alternator belt can cause squealing etc. Just wondering what people have used/ recommend. Currently in euro car parts they have Continental brand and a DayCo belt but I heard ( via ChrisFix) they a notorious for squeaking. Should I just buy OEM? Or is there something even better out there.
Thread Tools
(T) Changing alternator belt Cameron1590 Panda 4 17-07-2016 18:44
(T) Alternator Belt Changing Jimbothescot Cinquecento / Seicento 3 28-08-2015 16:25
(G) Got an Abarth? Thinking of changing the alternator belt? THINK AGAIN!!! gadge Stilo 10 15-08-2012 16:16
(T) Changing alternator belt VBScab Punto (Mk2/2b) 17 15-11-2010 17:22
(T) Changing the Alternator belt gregoreo425 Stilo 3 30-01-2007 09:53
