Technical Squeaking from front drivers side?
Josh5991
South wales
Car was all fine went to abarth day and went on track everything was normal on the 3 hour drive back the last 15 mins i noticed a weird squeaking noise coming from the front drivers side..
it would only squeak when going 5-15mph or when turning right, it stops when i put my foot down or when breaking.
we jacked the car up and the spring was moving would this be the shock by any chance?
car is a 08 punto abarth essesse
could be the spring moving against the rubber stop/sleeve...could be the top mount showing signs of wear...quickie is to spray wd 40 or similat at the spring ends ,one at a time to see if the lube stops the squeak..
