Thread Tools
Old 23-07-2017   #1
everson38 has donated!
Dog bine replacement
Hey guys
Have a GP TJET SPORTING 2009.
Been having a.mare trying to diagnose this front clunking sound, but am determined as I want to be sure I can diagnose properly.
Has anyone heard of your dog bone mount causing clunking and also does anyone have any information / idea on how to change it.
Thanks fiat family
Last edited by everson38; 23-07-2017 at 18:54. Reason: Spelt title wrong : DOG BONE
everson38 is offline Reply With Quote Quote
Old 23-07-2017   #2
Re: Dog bine replacement
Not sure what a dog bone mount is .. never heard of them.
If you mean the knuckle/cv joint in a driveshaft .. yes.. they can make a clonking noise.
Reach underneath the car and try twisting the driveshaft. Any slight play indicates wear in the knuckle .. the constant velocity joint. You would normally hear the clunk as you drove off/slowed down.
If the clonking is there all the time as you drive that may point to a problem with a broken spring or a worn bush - particularly when you go over a bump
Likes everson38 liked this post
glenn2602 is offline Reply With Quote Quote
Old 24-07-2017   #3
alexwr92 is offline Reply With Quote Quote
Old 24-07-2017   #4
Quote Originally Posted by alexwr92 View Post
Think you might be on about this mount it's the engine gearbox mount
Old 24-07-2017   #5
That doesn't usually a cause a clonk!... more like causes manifolds and fkexis to snap... my stilo did it... many times until diagnosed..
Current car: 06 Fiat Stilo Sporting 150 Multijet
Past cars: 03 Stilo 1.2 Active 16v, 06 Focus 1.4 LS, 98 E36 323is, 97 Astra 1.6, 95 Astra 1.7 TDI, 95 Micra Super S, 96 Almera 1.6 GX, 94 Micra Super S, 97 Vectra 1.6 Envoy, 98 A4 1.8T Sport
dtimmins1985 is offline Reply With Quote Quote
Old 1 Week Ago   #6
Hey for anyone with same issue. It turned out to be my drop links. But was hard to diagnose as the gaiters weren't damaged and they were sturdy when you tried.moving them by hand. In the end I had to have car on floor and reach behind wheel and have someone push down on bonnet and I felt it had play. Really happy as this has been a problem for some time . Thanks to all who helped
Likes PuntoR60SX liked this post
Old 1 Week Ago   #7
Belgium
Drop links have to be tested un-stressed, meaning the car sitting on its tyres, otherwise they would support the all suspension/brake/steering stuff and SEEM ok when loocking at play...
BRs, Bernie
Old 1 Week Ago   #8
Romania
I had a difficult time diagnosing drop links this time as well.
they would not move at all on the ground, on a lift or it any position.... so i was thinking it might be the strut mounts.... when i took the struts out (replaced with Bilstein B6) the droplinks were crap.. they moved so easily, so i replaced those as well.
Suspension is now 100% again.
FIY: the Bilstein B6 shocks are incredible (even with my stock springs) the ride is a lot firmer, and less roll, almost feels like it has a LSD.. no more spinning one of the tires.
aurick86 is offline Reply With Quote Quote
Old 1 Week Ago   #9
You should try B8s
1.2 8V Grande Punto and 1.6 Corsa Turbo
u33db is offline Reply With Quote Quote
Old 1 Week Ago   #10
Quote Originally Posted by aurick86 View Post
Good to hear it's not just me lol. So explain again if your droplinks were appearing fine on lift, ground etc. Why did removing the struts show it was them that were the problem.
Old 1 Week Ago   #11
Romania
To remove the struts, the drop links needed to be disconnected... and were immediately evident to be loose.
If you have ever seen new drop links, you will know they can barely be moved by hand, these were loose, easily drooping by gravity alone.
Old 1 Week Ago   #12
O yes I see what you mean. So dud u replace your struts even though they were not needed?
Old 1 Week Ago   #13
Romania
Well.. i knew at lest one was done, i had seen it leaking a last year, and now and then one of the drive wheels would spin/jump while accelerating from a standstill(an obvious sign), along with those the car felt heavier... it would crouch down more when braking, lean more in corners..etc.
Btw the ones I replaced were KYB, on the car for about 50k km, 3.5 years ... didn't last that well i'd say. Time will tel how the Bilsteins will cope.
Old 1 Week Ago   #14
Cheers for that Lil tip, neva new spinning wheels was a sign. Well at least it's not a waste seemed like they needed doing sooner rather than later. Yeah I've heard Bilston are a good.make but a pretty penny also lol. How.kuch did they set you back?
Old 1 Week Ago   #15
Romania
They were about 260 euro/front pair.. yah expensive... initially wanted the B4 those would be about 150 euro/front pair
Thread Tools
My dog Duffish Non-FIAT 1 23-01-2014 18:46
New dog and the GP marty61 Lets Talk FIAT 0 23-02-2009 16:47
My Dog Is Not Well At All clio Leisure Lounge 3 28-02-2007 15:08
OH my dog... Dazza Leisure Lounge 5 29-03-2006 14:05
The dog knows for sure Scooter Leisure Lounge 3 10-10-2003 19:05
