Thank you, I would have had that thought a few years ago but as long as you have the correct centre bore or spigot Rings to ensure the wheels rotate on the correct axis 2mm can easily be soaked up by wobble bolts/nuts in essence 4x98 to 4 x 100 etc, basically the cone on the bolt is effectively a washer with a slightly oversized hole, the wheel centres on the bore/spigot ring and the cones butt with the recesses with in the wheel, the bolts then pull up and the difference is taken up in play, hence wobble bolt. You then need wobble locking nuts etc, they are only 30 quid for a set. The wheels are currently being refurbished/straightened etc and should be ready for bending again on Lincolnshire's roads late next week. They don't wobble once tight lol
