Tomabraham17
- May 14, 2017
- 1
- 1
Currently having a problem with the car staying on. I used to have a problem where the car would not start at all because of faults including hill start failure, esp failure, and failure and so on. We cleaned up all the known earths that were indicated on a different thread and the car seemed to be working fine. However when the car gets up to temperature, the car tells me excess radiator cooling temperature. We've tried removing then coolant sensor and plugging it back in but it comes up with the same fault. We cleared it from the ecu and seemed to be fine. Then again when it gets to temperature it cuts off. Anybody got any ideas?
