I have a coolant leaking (so far I find coolant under the car, but no visible emptying on the expansion tank) on a t-jet, it seems to be coming somewhere from the heat exchanger, the heat insulation seems to be soaked in it. This is how far I got so far, cannot see more, and do not see an obvious place where the source is. Any help / common known leaks in this are are appreciated. For example, is the main water pipe sealed with an o-ring? This was giving way quite often on my Cinq.
