Hi Danny,
thanks for the compliment
Regarding the glow plugs, they should be ok for the engine life at least. No need for inspection/replacement like on petrol cars
Symptoms of failure would be difficult cold start in cold weather. Usually if you need to crank or do the pre-heating twice or more, you got one or more dead glow plug. Engine starting '
on three legs ' is similar symptom. To identify the bad one you can just ohm it; infinite resistance: open circuit : kaputt !
Don't have a multimeter ? Get a 12 V HALLOGEN bulb, a screw connector (called a 'sugar' in Belgium) with ca the same pitch as the bulb pins and two piece of wire (no need to be strong) connect both cables to the connector at the bulb, hook one cable to the plug and the other to POSITIVE of the battery. The bulb should lit if the plug is ok...
The plugs are simply bolt in the engine. On COLD engine, the day before, squirt some WD40 or your preferred un-seizer on the threads; on D day carefully losen and unscrew the plug using a long version socket WELL ALIGNED with the plug. Use your power sparingly, no high torque, no lever bar... The tightening torque is only 0.9 to 1.1 daNm (1 mKg).
Regards, Bernie
