Technical Grande Punto Radio Connections
Do you need help unlocking your radio?
Get your code instantly using our radio unlock service 🔓🎶
anyzunstudios
Grande Punto "FastLine"
Spain
Hello everybody, I want to get a good wiring diagram about radio Connections on my Fiat Grande Punto December 2007. My car has standard radio system, not blackpunt. I want this because I want to get Can High and Can Low to check a Project that I am developing.
Thanks in advance!
Either way, there should be a plug pinout diagram on the top of the headunit you are taking out ;)
Here it is:
DIAGRAM:
RADIO UNIT:
Now, the problem is what CAN (A or B) is CAN High and CAN Low?
And, what CAN Protocol is used?
Thanks in advance!
CAN B is high, and CAN A is low
Page 2 of the following: http://www.speedsignal.de/Dokus/342_ADIF/en/342FI01.pdf
Thanks! But after checking so, I've screwed a bit my Fiat hahaha Now shows a error message about airbag failure, but thanksfully to AlfaOBD and an OBDII diagnosis adapter, I could fixed my mistake (the failure was at radio connections).
Can be that CAN-A CAN-B are different CAN circuits? Thanks in advance!
Really? I've only seen one design of radio with different button labels, I presume the MP3 or blank is Grundig and Blaupunkt is Blaupunkt? Are there any audio differences?
I don't think so. Maybe better sound quality? High-tech experinence? Felling better that other poor people that have basic radio? Who knows hahaha :D:D
