Hi Thorpy & All,
I just wanted to warn about "putting spanner across" !
You replied once "engine battery" and in the very next post "will it arc when putting spanner across" ... That might be confusing for less experienced readers
Ransonman was clear about shunting the FUSE with a spanner, but hey, some Guys might just jump to the last post to get the solution...
And BTW, the best way to check the fuse is to mesure the voltage drop across it when drawing current in this particular circuit; it should be very close to zero (a few mV)
Regards, Bernie
If someone helped You fix or understand your issue here, hit the thanks button, it costs nothing...
