A friend has a 57 plate Grande Punto Sport
It used to start fine then one day it wouldn't start and immobiliser just kicks in.
He bought a 2nd hand ECU along with the key/ignition and the clocks.
I changed the blade in the key so we didn't have to change the ignition and put the ECU on the car but it is the same.
If you turn the key quick it does turn over but the immobiliser light comes on, if you leave key turned forward without trying to start the car after a few seconds the light comes on
Do the clocks need to be changed as well also do we need to put the immobiliser reader off the new ignition on the car as well?
Thanks in advance for any help
