Hello all, Long time no post.
I am needing some assistance diagnosing an issue with my Brothers 2006 Grande Punto 1.2 8v. One morning it just refused to start, not even trying to crank and displaying the "vehicle immobilised" light.
I gave it a quick inspection and found that the main 70amp Midi fuse had blown, I was able to start the engine by bypassing the fuse with a spanner so I replaced the fuse but it still wouldn't start, even with bypassing the fuse.
I tried a spare battery, no change and I added an additional earth to the geabox (the main engine earth had been replaced 2 years ago after it failed).
Now, completely randomly it will allow me to start and when it does if the engine is stone cold it will run... for about 5 miles, then it will start loosing all power for a second before coming back to life. If I am really unlucky the the immobilisor light will come on and I will be stuck on the main road constantly re-trying untill the immobilisor wants to let the car run.
Once this happens the car will not idle for more than 10 seconds, it just randomly stops. If I hold the revs higher than idle then It won't stall but it will keep loosing power momentarily.
If I watch via Multi ECU scan the battery voltage is constantly fluctuating between 11.5 and 12.5 volts but measured on the battery is a solid stable 14v. The Engine ECU logs not faults at all. The "Engine startup allowed" parameter shows "allowed" if the engine is running but doesn't show anything at all if the engine is immobilised.
If I query the ABS ECU and the Power steering ECU's I get a load of faults (I don't have the codes on me right now though) mostly relating to loss of CAN bus connectivity. The electric windows don't work and apparently stopped working around a year ago.
I believe this is indicating a faulty Body computer but I don't have my yellow ELM adapter on my to query the ECU. Can anyone recomend anything else to look at and to try. If I need to replace the ECU, what components do I specifically need?
Thanks all.
Thanks all.
