fiat grnade punto 2006-07
tetnulda
hello guys, sorry if I use no correct place for my thread, I'm new member. Need some help, on my fiat grande punto not working horn and SRS light is on every time. any advice? can anybody help? please tell me How to Fix this problem. thanks to all
varesecrazy;Hi said:
thank you, man, but it will not help me. mechanics said me that it is problem of flex cable of steering-wheel and in fiat center Tbilisi (Georgia) they told me that this cable costs 430$. I think it is too much, can you show me any online shop to buy this cable. I cant find it on ebay thank you
hi,
find the part number;
http://eper.fiatforum.com/eper/navi...INT_MODE=0&EPER_CAT=SP&WINDOW_ID=1&GUI_LANG=3
GM/Opel parts are cheaper than the FIAT version here in the UK,
maybe the same in Georgia,
Charlie
I can't find what I need. don't know what to do. :((( any ideas?
Sounds like the clock spring has failed but First check to see if power is at the horn and switching when the horn button is pressed.
You should get a diagnostic check carried out on the airbag system.
If you do need a clock spring unit, call your local fiat agent/dealership and ask for the part number then you can try find the correct part cheaper elsewhere. Maybe eBay.?
In fiat center Tbilisi, Georgia they told me it is flex cable which is in the steering-wheel, airbag lights on every time and horn does not works. and does not works ECO button. everything other is in good condition, I drive it every day.
engine is 1.4 8v, gearbox is dualogic.
the part they told me in russian sounds like рулевой шлейф. if it helps you :)
hi, :)
as Thefox says it is quite possibly the clock spring
here is an image;https://www.google.co.uk/search?q=g...=aRwsWJToDoHVgAaw_azIBw#imgrc=0WJ5m9SmTuYzuM:
in Google images - there is picture from a FIAT used parts specialist in the UK, ;)
here is an excellent thread - could well be the same fualt..;
https://www.fiatforum.com/grande-punto/314658-airbag-failure-honk-audio-controls-not-working.html
Charlie
thank you man, thank you! but I could not find any part which fits to my car, couse it has cruise control and back glass cleaner. :(
hey hey what does it want? what problem? all oils are good and new, yesterday I stopped it in garage and today morning it does not works, automatic does not work, manual lets me to put in 1 but does not goes, engine has no reaction about pressing pedal.
