Hello everyone
Recently my GP 1.4 8v 2006 developed whinning noise when I press on gas pedal. I can hear the whinning in 1st 2nd and 3rd gear no noise in neutral the whinning starts on 2000rpm and goes away after 3000rpm or when I let my foot off the gas. It makes me think it is the gearbox but why it only makes the noise in certain rpm, the oil in the gearbox was replaced 3 months ago and all the gears shift smoothly and surly the gerbox should last longer then 65000 miles. Also i have engine oil leak somewhere I have to add 500ml of oil every 4 months when I took off the Air box I have notice some oil in the throttle body (the seal between the box and throttle body was damaged) which I have replaced. I have checked Air inteake and can't see any leak.
My question is did anyone have similar problem or know where the noise may be coming from ?
It really makes me thing that it's the gearbox but other then that it's fine or it might be something to do with the oil in throttle body ?
(I will try to record the sound leater on)
