Lamps by Post - For all your lighting needs
Thread Tools
Old 23-10-2016   #1
Fiat grande punto 2006 warning bulb light
Hi, so I keep getting the bulb warning light as I turn my side lights and main beams on... checked bulbs and fuses, all seem good....any ideas?
ejarin is offline Reply With Quote Quote
Old 23-10-2016   #2
Ireland
Re: Fiat grande punto 2006 warning bulb light
Are all bulbs the correct wattage?
digger58 is offline Reply With Quote Quote
Old 24-10-2016   #3
Became old and sensible
brickfoot's Avatar
brickfoot has donated!
Check all bulbs are working.
Front:
2x Dipped/Main beam
2x Sidelights
2x Indicators
2x Front fogs (if fitted)
Rear:
4x Sidelights
2x Brakelights (on the lower bulb of the sidelights)
1x Centre brakelight
2x Indicators
1x Reverse
1x Rear fog
2x Numberplate lights
Check all of the above. If they are lit, they will be fine. If they are dim, replace the bulb.
Likes digger58 liked this post
Current Garage
Mine: 2013 VW Passat Sport BlueMotion Tech 2.0 TDI ReMapped
Hers: 2006 Fiat Grande Punto Sporting 1.9 M-Jet
brickfoot is offline Reply With Quote Quote
Old 24-10-2016   #4
Ireland
Mine was acting up as well, turned it was one of the bubs in the high level brake light was blown!
Thread Tools
(T) grande punto reversing light bulb fairview1 Grande Punto 7 02-05-2014 20:19
(T) grande punto 2006 centre brake light owen1107 Grande Punto 4 19-07-2010 22:08
(T) Failed bulb warning light on 2005 Punto. kipster Punto (Mk2/2b) 5 22-12-2007 20:03
