Technical Flashing Check Engine Light
nickbutler
I have a Fiat Grande Punto, 59 Plate, 1.4, 8v, 71000 miles
I had a timing belt and water pump change as well as a interim service done on Monday.
Drove it home Monday (15miles) without any issues.
Driving to work on Tuesday, the check engine light came on and flashed around 6 times before turning off and not appearing for the remainder of the 30 minutes of my journey. It did the exact same again on the way home, and also on the way to work this morning.
It occurs travelling at around 70MPH (apart from the journey home from the garage on monday) when I have been at that speed for a few minutes, but it only does this once per journey.
The car sounds and feels absolutely fine. Oil levels are normal and fuel consumption seems normal so far.
I will be plugging it in to hopefully read a code once I am home, but does anyone have any initial thoughts?
(Just so you know, I know little about cars! )
Thanks in advance!
Same happened on the way home..flashed 3 times at around 70 mph then never returned for the rest of the journey.. no codes have been stored either according to my device
