Deckchair, If you're still around! I have a 2006 Grande Punto 3dr and the drivers door doesn't wake up the interior light. I have removed the door lock and tried to take it apart to see if I could get the switch to work. Wasn't very successful. Do you happen to know which colour wire in the lock plug I can connect to which to check if its the lock or something else that is the problem. I did pull apart the connector on the a pillar and tried some cleaner and put it back together with no joy.
