Hello all,
I'm hoping someone can assist with an issue I have with the passenger window not working correctly on my wife's car. Only brought the car recently, it appears someone disconnected the cable inside the door for the motor previously and when connected the window would go down but not up.
I've already proven this is a broken cable issue as when I inverted the connections at the motor the window would then go up fine...so presently it is disconnected.
I've read through the other threads for any advice but I've come up with noting useful just yet.
I've proven continuity between the window switch and the motor but now need to extend my checks through the rest of the loom so I can find the break, disconnected the connector where the loom goes into the car body but I have no pinout diagrams to assist me.
I've downloaded the elearn for the grande punto but can't work out how to access it correctly, so if someone could point me in the direction of a pin out diagram that would assist me great, or alternatively provide me the instructions how to use the elearn I'd appreciate it, many thanks in advance
