Cheers people
I done it exactly how the Haynes manual says, locked the cam and crankshaft off, slipped the old belt off and fitted the new belt and tensioner and set the tension, rotated the crank 2 times, lined up the timing marks, released the locking tools and put it all back together, tbh I started it up and it sounded a bit squeaky so I may have put the crank pulley on wrong or tensioned the fan belt to much.
I am also aware that I need to fit a new rocker cover gasket, but just wanted to see that I done everything ok, so I'll fit a new gasket and check the crank pulley but other than that all sensors went back in the way they came off???
I will also see if I can get a code reader.
Cheers??????
I'm in Essex m8where are you?
i had a light because the timing was out P0016
so if your out by one tooth it could put this up
was the light on before you did the belt?
cheers craig
I'm in Essex m8
Light was not on before I did the belt, I locked the cam and crank so timing shouldn't be out, started the car and it seems to be running ok, bit reluctant to drive as the EML is still on, don't want to risk it, if I was out a tooth or by a few it would show in the running and timing ??????
I think I need the code reader, if it comes up as timing belt I'll re do it again and see if it clears then.
yeah you need to get the code read first it could be anything check all connection first before doing time again i'm a bit far away to plug in and check hopefully someone on here thats more local
No probs
Cheers for the input anyway
Cheers m8
I ain't got a laptop, we got rid of them when we got iPhones, is there an app that does it??? If not I'll see if I can get one on the cheap.??
Thanks anyway, really appreciate it??????
If you want to access OBD sensors/error codes etc from the iPhone, get the ELM327 WIFI from ebay and download EOBD-facile from the appstore
I'm in Essex m8
Code cleared, all done, running fine, got to adjust fan belt and install new rocker cover gasket but seems ok, needs a wheel bearing but I've done loads of them, so should be straightforward fix.
Thanks for the help chaps??????
