Hi guys,
Looking for your help with a front end knock I'm having on my 06 1.9 GP remapped to ~175 BHP thats is at 113K miles.
The knocking is present under hard ish acceleration at lower speeds which is worse when cornering, a good example is a brisk pull away from a T junction. It can also happen over pot holes and when aggressively engaging/disengaging the clutch.
I know it is not the following:
- drop links (replaced)
- lower engine mount (replaced)
- half shafts (worked as a halfshaft engineer for 4 years)
I have also checked the bushes and not seen anything obvious.
please let me know what you are thinking the issue could be, any suggestions are appreciated!!
Cheers all,
Rob
Cheers all,
Rob
