Really after some advice, but i'll try to keep this short.
Had my thermostat changed about a month ago with one I purchased off ebay (big mistake)! Turned out I didnt have a faulty thermostat, but was my water pump, so long with changing the waterpump they replaced my cam belt at the same time as it was due.
Week later driving along and lots of steam coming from under bonnet. Called out recovery who advised the thermostat had broken causing coolant to be sprayed everywhere. Towed to garage and they ordered me a theromstat and replaced it.
A week later noticed my coolant was very low, so bought some and topped it up. Few days later it has dropped a bit so took it back to the garage. They tested it all and said it was a loose jubliee clip.
Week later, noticed again my coolant was running low. Took it back and only just got it back today after 3 days of testing. This is what ive been told.
My car has a problem with the pressure. As soon as they fix one leak, another one somewhere else starts up. Theres also quite a thick pipe leading into the engine, they said that it is absolutely rock solid when it shouldn't be.
They believe it might be the start of the head gasket going. For the time being they have put some special formular in that is supposed to stop leaks, but ive been advised for the time being to keep checking on the coolant.
There advise is to look at trading it in somewhere before its too late.
Any help/tips advice greatly appreciated. My car is a 56 plate GP 1.9 Sport
