Hello all,
Need some general help with my Fiat.
The Gearbox has been playing for a while until today as the car is not longer starting. The Dualogic Gearbox would sometimes not engage the Reverse and make a terrible noise and then not back into neutral, after playing a little bit with it, the car goes fine.
Today, after parking the car, I turned the engine with the reverse on the gearstick. The buzzer went off again but would not stick back to Neutral or 1st Gear, i decided to turn off the car and turn it back on again and now is making a click-crank noise without doing anything else at all and always on the N gear.
If I only turn the car on and I press the brake (which i understand in these cars this would be the clutch) I can hear the Click-Crank again only once, and without fully turning the key to start the car.
Any ideas? I have tested the battery and is all good, all the electricals in good working order. Should I connect my car to a computer to find out what's wrong?
From where do I need to start?
Thank you very much
Thank you very much
