Nathan6597
So after plugging my car into my Works Snap-On Solus Pro. The BCM has flagged the following Fault codes.
B1022
B1035
B1011
B1007
Of which 1 is a code for the BCM and the other 3 are for the two tailights and an indicator. Is there anyone that has had an issue similar to this. Or anyone with experience and knowledge that will be able to help with what the possible faults that is causing this, burying in mind that in my other thread, I mentioned that I checked all the rear light terminals and cleaned them with a wire brush and leccy cleaner.
B1022
B1035
B1011
B1007
