DaveHolland
- Feb 22, 2016
- 13
- 4
Hi All,
Long time lurker on these forums but just posting for a bit of general help/advice
Last weekend I changed the front coil springs/top mounts on my GP 1.9 130 as well as the front discs and pads. Since then I've noticed the car pulling slightly to the right, not dangerously so but requiring a constant slight steering input left to correct it.
I originally thought the springs may not be seated properly or the strut had become distorted but I think it's more likely the front right brake that is binding slightly. Doing the 'driving with your head out the window' bit gets some funny looks but I could at least hear a slight squeal from the front right. This morning when doing a hill start I found that coming off the brakes, the car was staying stationary for about 2-3 seconds before starting to roll backwards when the caliper then fully released. This is not noticeable when pulling off with a normal amount of throttle.
I've changed a good few discs and pads on this and other cars before and haven't come across this. To summarise the symptoms:
I know the Pandas and 500s had something similar but I think the setup is different on the GP. I'll be stripping it back down tomorrow to investigate but any suggestions as to what to check first?
- Slight squeal from front right brake
- Car pulls slightly to the right
- Front right caliper sticks when pedal is released
- Brake pedal itself does not return as quickly
- Pedal does not feel spongy and doesn't have excessive travel
- Stopping distances do not appear to be affected
- Noticed no difficulty with acceleration
