Technical Brake lights problem
Redley
Hello,
I have a problem with the brake lights that I can't figure out. The rear high level light works fine, so it's not the fuse. I've checked the bulbs and they all seem to be fine, I've cleaned some corrosion off the mounts and cleaned the connectors as there was an intermittent earth issue on an indicator recently.
The indicators work, the rear high level brake light works, the rear lights work. Just not the left and right brake light, any ideas?
Thanks in advance.
