Technical grande punto heater problem
ruskin
Hi, I'm a new member so be gentle with me :) My granddaughter's Grande Punto's heater doesn't warm up. Nothing to do with the internal fan. I've fixed that. She recently had a new water pump fitted so the likelyhood is that there is an air lokk in the system. Any tips on bleeding the system, in particular,the system. Any help would be appreciated to save me going around the houses. She erxpects me to fix things in 5 minutes LOL. Cheers and thanks in advance. Michael
I had a nightmare with my grande bleeding the system, in the end I disconnected a pipe from the radiator and pushed a garden hose in and blasted water around the system to push all the air out. Worked quite well in the end and never had any more problems.
Are you sure that before the water pump replacement heater was fine?
