Hi all,
I have a 2007 grande punto 1.2 active, 85k miles ish
I have recently had power/misfire issues with eml sometimes coming on.
Codes I have read myself with cheap reader are
-p0300 random/multiple misfire detected
-p0302 cylinder 2 misfire detected
-p0303 cylinder 3 misfire detected
-p0202 injector circuit - cylinder 2
A month ago there would be a very occasional loss of power accelerating(misfire?) with eml coming on intermittently.
A week ago it worsened with much more loss of power, occasionally running rough on tick over which I presume is a misfire?
Plugs, leads, coilpack and MAP sensor have been changed a couple of days ago. Car then ran fine for a couple of hours use, then this evening had same symptoms and is sounding rough constantly.
A year ago the cam belt was changed, this seemed to coincide with the start of the eml coming on every now and then and going off(misfire fault codes only but no physical symptoms).
I thought this was a false fault as I have read about a sensor misreading the misfire as the cam belt was not changed by fiat dealer.
Also a bit more history.... during a service it was noticed that an exhaust manifold bolt was missing/broken off and when the engine is cold it was blowing slightly (didnt know if this would affect anything and was left)
Please does anyone have any suggestions??
I dont want to have to waste money trying to eliminate problems
Many thanks.
Craig
Many thanks.
Craig
