Hi All,
Car developed a slight misfire:
Occurs between about 1200 & 1500 RPM only and most noticeable on lift off of throttle when it can be clearly heard and felt. If slowing down in 4th or 5th, when engine speed hits above range the car jumps a bit sort of like a kangaroo start from bad clutch control.
No check light
Plugs replaced about 1000 miles ago (gen. Fiat parts) and old plugs looked OK
HT Leads look in excellent condition
Air filter & oil filter all new and correct.
Breathers not split
Fuel economy not changed
No noticeable hesitation on acceleration
Worse when car is on "choke", i.e cold
2006 1.4 8v Active sport.
Any suggestions would be appreciated.
Thanks in advance
Ben
No check light
Breathers not split
Thanks in advance
Ben
